Remote Access Not Working
Server Version#:4.47.3 on a win 10 machine
Player Version#:Android, web, fire tv stick (basically it doesnt work on any device)
I am trying to set up the server for remote access. it is running good in my network. transcoding works fine and everything. but i cant get it to work outside my network. when i click the retry button it says “fully accessible outside your network”
but i cant connect to it. and as soon as i click onto another setting tab it switches to the red error symbol thing.
i forwarded all the ports on my router and enabled upnp. i basically tried everything i could find on the internet but it doesnt work. is there anything i am doing wrong?
Did you fix this problem or got a respond. I’m having the same issue.
yes, i actually got it working. i simply deleted all the port forwards and redid them, that just solved it for me. i have no idea why it works all the sudden. but that might help in your case as well.
