Remote access not working
Server Version#: 1.43.0.10492-720010492
Player Version#: 1.112.0.359-0d79a49f
I have this issue where I can play media from home on my local net work no problem.
Thus, when I try to use remote access, I can browse the catalog but when I try to play media this message appear:
I tried :
manual port forwarding
max out video settings to avoid transcoding
please help me
Have you checked if music streaming works?
That’s something that is very low bandwidth and will direct play on almost all media types.
And you can test it easily by just disabling the wi-fi on your smartphone so it’s using mobile data.
