Remote Access - Port Forwarding
Server Version#: Version 4.157.0
Player Version#: Windows / Brave
Hi. Sorry in advance, I’m a newbie to this. I’ve tried to follow the guide to get remote viewing set up. I’m trying to set up a port on my router and I’m on this page - sorry about the language, I live in Spain but hopefully it makes sense.
I’m adding the information as such:
Nombre: Plex
Direccion IP: The IP that shows on https://canyouseeme.org/
Protocolo: TCP
WAN: 32400:32400
LAN: 32400:32400
However, it won’t let me add the rule with this. Am I missing something?
Thanks so much!
is the ip of the Plex Server
^^^ Precisely.
Additonally, I recommend to use a different random port number for the WAN port. (pick one from 20,000–50,000)
Then put this exact same number into the Plex configuration, at Settings - [server] - Remote Access - ‘Show Advanced’ - “Manually specify public port”
@OttoKerner hi, thanks for your help, it seems to be working :slight_smile: much appreciated, have a great day!
Oh one more question - it won’t work with a VPN on, is that correct?
If you use a VPN on the Plex server machine, see to it that it supports “Split-tunneling”. What it does is exempting certain apps from the VPN.
Connections between Plex clients and the Plex server are already encrypted. I don’t see sense in encrypting it a second time.
Thank you :slight_smile:
I reset my router earlier and this is no longer working, I’m not sure if I’m missing something.
My settings are:
Direccion IP: The IP that shows on the remote page (the one listed as ‘private’
Protocolo: TCP
WAN: 31000:31000
LAN: 32400:32400
It doesn’t connect.
I’ve been having problems with Plex all day, I’m not sure if it’s related.
