Remote access red X when using IPVanish
Server Version#:Most Recent
Player Version#:Most recent and ALL
Everything works as it should when VPN not running. I’d like to get remote access with VPN on. Port forwarding seems to be set up properly but I’m not sure. Can someone walk me thru this?
If someone has a good answer to this I would have loved it a few years ago. I ended up puting PLEX on its own PC without a VPN so I could keep my main PC on the VPN. I tried several times to get PLEX to work with a VPN and just gave up. I had an unused PC so I just put PLEX there. Solved my problem but I understand it isn’t techincally a solution to THE problem. Hopefully someone will chime in.
Here are some other threads on this.
should Plex ultimately see my modems public IP address or my VPNs IP address?
Honestly I don’t know. As I said, I could never get it to work. That’s why I just moved PLEX to a stand alone PC that does nothing but PLEX. Give this thread some time and see who responds.
thank you for your response. Hope this gets sorted out. Also chatting with IP vanish now too. If I get a working solution I’ll reply back here too
I use PIA without issue, IPVanish only supports split tunneling with android I believe.
Just ended my sub with ipvanish and started a year with PIA. I think this is resolved. When checking 32400, it shows on the home IP, not the VPN correct? (Question for SE56).
If using split tunneling correct, I found it best to use a non default browser for Plex admin and add the Browser to exclusions. Add all things Plex to Exclusions
