I cannot directly access my Plex server from outside my network. I have the port forwarding set on the network but then noticed that the public port was :0 instead of :xxxx.
Can this be changed, and if yes how?
Thx
You need to tick the checkbox and put in the external port number you used in your port forwarding.
Could have sworn I tried that. Working now, thx.
