Remote Clients not Respecting Language Subtitle Settings
On my server, under languages, I have the subtitle mode set to manually selected.
I’ve ripped all of our media using MakeMKV and transcoded everything using Handbrake. I only recently realized that Handbrake was flagging subtitles ripped from DVDs and “default.” When playing media back locally, because of the subtitle mode selected, no subtitles are every selected by default.
I created managed users for my parents and my brother for them to have access to my Plex server. When they playback any media that was ripped from DVDs, subtitles are automatically selected and are burned in. The video is transcoding anyway, so I’m not worried about that, but they would have to manually disable subtitles every time when they shouldn’t be playing anyway.
My brother is using a Roku and my parents are using a Fire TV. I looked at the settings for the Fire TV tonight and don’t see anything about subtitles other than whether they should be burned in and then some settings for how they are displayed.
I haven’t bothered calling to go over the setting on the Roku, but I know they don’t have them turned on in the actual Roku settings.
Why would Plex respect this setting locally, but not remotely?
Audio and sub settings are per account, not per server. Each user “account” can set the desire setting. This includes all Managed Users aswell.
Click HERE and select the Manage User.
More Info here.
https://support.plex.tv/articles/204985278-account-audio-subtitle-language-settings/
For remotely or remote family/friends accounts you can give them the below.
They will have to set it themselves.
https://app.plex.tv/desktop#!/account/audio-subtitle
So out of curiosity, what are the other subtitle settings under: Settings>Languages ? Why have 2 spots for language and subtitles selection if it’s per account? Just curious, as I’d like to know more…
Via link above
Audio & Subtitle Settings
  • These settings determine how Plex will try to select audio and subtitle tracks when playing media in a Plex app while using your account.
Setting>Languages is for the PlexWeb player.
Ahh… That makes “some” sense… I wonder why they couldn’t just lump them into the account settings? but that’s neither here nor there. Thanks!
Did some more testing and discovered both settings will change PlexWeb & Plex apps(Roku app at least) behavior.
Though, I can tell you that Settings>Languages is only available to users that have a plex server.
I can only assume that the topic came up in discussion and it was decided to allow every account the ability to manage their own audio/sub settings.
Hence the setting via link above. I guess there is no need in detecting if you own a server and disabling one of the settings.
Guess now the Setting>Languages setting is just a evolutionary leftover, lol…
Yep and this actually makes sense.
Setting the server to my native English is fine to a point but per account makes far more sense.
So if watching a German movie like Sophie Scholl Plex knows that I’m gonna be needing the English subs.
For my German-speaking friend having those English subs on by default would be pretty pointless and annoying.
Meanwhile, neither of us are particularly fluent in Klingon or Dothraki so the forced subs setting handle that too.
It can’t always be said but Plex really nailed this. :stuck_out_tongue:
I also noticed the https://app.plex.tv/desktop#!/account/audio-subtitle has more options and includes sub’s on demand. Something Setting>Languages doesn’t have.
I’m sure in the years to come and the dev’s feel confident the path they took in the app.plex.tv hosted setting they may remove the other(maybe)… Cause something is to be said for “offline” choices. Without it, the server admins out there would have to go “online” to administer that server setting…
I think you’re mostly correct… My issue comes with Anime. While I am a native English speaker, and currently learning Japanese, I still need English Subtitles because I am not fluent and prefer my Anime in Japanese.
So Ideally, I’d like the “Shown with Foreign Audio” to actually check against the Language setting and not the “Preferred Audio Language” setting. Because then I could select my preferred audio language as Japanese, this way I didn’t have to fiddle with each episode. This would accomplish:
  1. My English content plays fine without subtitles as there’s no Japanese audio tracks
  2. My Anime auto-selects Japanese Audio and Displays English Subtitles
Currently, for the anime that I have that is Dual Audio, most of it is set to English as the first track and it’s also usually the default track. Rather than going through the 400+ episodes that are like this and stripping the English Audio, or moving it to the second track and removing the default flags, it would be much easier if Plex handled this on its own, and simply changing which “language” field the “Display with foreign audio” looks at would accomplish that.
I’m glad you have not gone this way. Plex doesn’t do well with default flags.
Yeah, I am actually going to be just batch processing all of my anime into x265 (to save space), and in that process I am going to setup Handbrake to only use Japanese Audio Tracks and burn in the English Subtitles… But this is going to take a while.
That will almost certainly mean that Plex will need to transcode all your anime
I tested with several TV Shows I’ve been recording. I’m direct playing all x265 content on my primary devices… When I use soft subtitles, it transcodes, but that’s why I’ll be burning them in
Congrats!
A very good point that I had overlooked.
With a choice of…
  1. dubbed audio and no subs
  2. Original audio and subs
    Well, option one would never be considered.
    With something like Anime I guess it would be different.
This puzzled me. What client are you using that doesn’t support x265 in direct play. :open_mouth:
I always used a Roku3 and Android… but maybe my issue is because my old plex server version. It’s been a very long time since I tested x265 …
I figured as much, but I was looking for the language settings under each account! Guess I just missed them on the account page for each.
Thanks so much! This was driving me crazy.
