Remote Plex Poor Performance
Server Version#: Version 1.15.6.1079
Player Version#: 7.17.0 - Android
Galaxy S7
AT&T
Plex use to run great remote, then the server software was updated, I could not connect. I fixed the remote issue and now can connect. When I select a movie, I get the turning circle, then the movie will start, then back to a stopped moving with the turning circle.
I did enable the ability for the server to downgrade the picture to keep the moving running. That did not improve anyting.
Still confused what happened with the server software update. Remote worked fine before.
Thanks.
This topic was automatically closed after 90 days. New replies are no longer allowed.
