Hello,
Every time I reboot my server the remote access works for some time, but after a while it will try and connect to the wrong private IP (it will try to connect to ens5 with ip 10.0.0.1). I have 2 network interfaces, one (eno1 192.168.0.25 is for internet && outside connections) the other one is ens5 (10.0.0.1) this is only for SMB sharing. Plex normally selects the correct interface right out of the box (eno1 normally) , wel not this time for me …
. I tryed to change the interface in the “network” tab in the PMS settings, without any success. I also added my iptabes in the picture below, they allow PMS to go through on the eno1 interface and just for testing purposes I blocked it on the ens5 interface.
Is there anything more am doing wrong, I used to do this all the time (have being using plex for 2 years).
Maybe this is just the latest update that is causing this, or does anybody have the same problem and found a solution ?
Server Version#: Ubuntu 18.04 - PMS Version 1.13.6.5339
Player Version#: Web Client Version 3.67.1
Greetings.
