Remote Server automatically converting files to SD
Remote server used to stream on HD. Latest updates and now Automatically converted to SD. No settings will change this. My phone works fine doing the same thing on HD.
Very Annoyed!
On what platform are you missing the respective „remote video quality“ settings?
Android TV Latest Update. worked in HD before update around July was applied.
Phone did appear to work in HD, but automatically converts to 480.
Speeds range from 10Mbps to above
