Just updated to 0.6.0 and my remote no longer works.
I am using a USB to Xbox (original Xbox) cable and Xbox DVD remote, it has been working absolutely fine up until 0.60
Any suggestions ?
Any suggestions ?
I had a similar issue when running OpenELEC for normal media centre duties before I moved to Plex.
The fix was to install these files, in the folders that they are in the archive, and it all came back:
https://www.dropbox.com/s/41ctqm4cjrx5rer/xboxremote.rar?dl=0
But, it did break on the next update... so I've actually found HDMI-CEC is working far more reliably, with some suitable tweaks to my Amp settings (enabled "HDMI Direct") it's actually far more reliable, and saves me a USB port.
Thanks for the response, can you check the link, it doesnt work for me :(
OK link seems to have started working again, trying files now
All working again, thanks very much :)
