Either allow option to DISABLE or CONFIRM when “Remove from Continue Watching” is selected.
Several times I’ve accidentally hit “Remove from Continue Watching” and is a pain to restore, and is causing problems. Now one of my shows that this was accidentally hit won’t stay in my Deck when new episodes are populated. Either let me disable it as I will likely NEVER use it, or popup a simple confirmation box to ensure you meant to remove it. This is really causing trouble, not to mention it is in the WRONG location in the R-click menu…
DISABLE or CONFIRM: either should be simple to code.
