Removed Plex, now can't reinstall. HELP!
Removed Plex as it would not update, so I’m trying to do a fresh install on Windows10.
TO UNINSTALL I:
—Uninstalled using Windows Remove Program
—Then deleted Plex from Registry
—Then removed the LOCALAPPDATA folder
WHEN I TRY TO REINSTALL:
I keep getting the same message: “Previous installer data found without “UninstallString” value. Please remove Plex Media Server manually first”
I cannot find any “previous installer data” or anything else Plex-related anywhere.
I’m at my wits end. ANY SUGGESTIONS — PLEASE.
Screenshot 2022-11-07 18.29.07
https://support.plex.tv/articles/202967086-windows-errors-trying-to-upgrade-install-or-uninstall-plex-media-server/
TY, but already did this.
Did what exactly?
Followed the instructions on that page, exactly.
And to be clear, the Microsoft “Install and Uninstall Troubleshooter” can also find no trace of Plex to uninstall.
See if it can find traces of pms-shutdown.msi still present. Let it uninstall this as well.
Do also empty out the temp folder etc.
I appreciate your help, but in the end I’ve tried everything but can’t reinstall.
I’m running it on another PC, but am so frustrated with Plex that I have now installed a competitive product and am happy with it (especially the ability to sort photo libraries by time, date, name, etc., a feature that Plex has always lacked).
But thank you.
