Removing Devices not working
Hey all,
I know you can sign out of all devices when you change your password. I only have 1 device that I need removed. I changed the password and removed the device, but it still has access. I have restarted the server, waited a couple days and it still did not remove it. I would prefer to not have to sign every device out. Is there a fix for this?
Also, I have disabled remote access in the server settings, but somehow some devices can still connect remotely. If I disable remotely it should not allow any remote access.
Maybe connecting via Plex Relay service?
Disable Secure Connections in Settings → Server → Network and restart PMS.
Reference:
