I have a large number of movies that do not exist on any database, so I have added metadata manually for them.
I want to rename their folder names by appending the release year in parenthesis but if I do this, then Plex thinks it is a new movie and creates a new entry for it, trying to find metadata online for it.
How can I rename those folders, without having to type again all metadata for each one of those movies?
Try to copy a folder (and its content) and rename it to the desired format.
Then perform the library update and see if Plex has recognized the file as a duplicate, using its ‘bogohash’ value.
If that was successful, you can delete the ‘original’ folder and update the library once again and then empty the trash.
The duplicate thing didn’t work.
I will try to edit the database directly, but that’s gonna need some time for research on my end, since I am not comfortable working with databases.
If I manage to do it, I’ll try to post a description here. However, would be good for Plex to have an option to change the file to which each entry is associated. Now, under Edit>info I can see the file name and path, but can’t change it.
