Rendering error causes media not to play
Ps: Where did music tab go? And really like the new title logo thing, always wanted it on plex eveytime I went to Netflix, you guys keep up the good work. Many thanks.
Music is only available in the Plexamp app now.
Appreciate the reply just more annoyed that the media doesn’t even play, I’m sure they will fix this issue in good time, thanks Lazarus.
There’s nothing to “fix”. Plex said this is the way it will be going forward.
The “fix” OP is asking about is related to the MediaCodecVideoRenderer error (unrelated to music)
My bad, that’s what I get for skimming. :slight_smile:
No worries.
Same issue since the latest UI revamp patch. I can’t continue shows I’ve been watching because of it.
You would have thought this would have been checked before release although the release is still just a preview, I don’t know what hardware you have but mine is deffinatley on the lower end, maybe this could play a factor, but still it is very unfortunate for us right now. Thanks for the comment, my fingers are crossed. Have a nice day.
I fixed this by disabling hevc video encoding (experimental) set it to never in transcode server settings and videos now transcode and work fine on Plex mobile
I simply don’t expect involuntary updates ( code push updates ) to brick an app for such a long period of time with no easy way of going back.
You could say that again.
Im glad you found a fix for yourself but for me it was already set to never and still doesn’t work, appreciate the comment though. Have a nice evening.
I have hevc encoding turned off but this still happens.
Thanks for experimenting, i wish this would just work already.
I wasn’t experimenting. This is just my setting. I don’t need to encode to HEVC.
Same problem for me.
Last night I started watching a video, today I wanted to continue but Plex App pushed an update on my device and now I cannot play it any more.
Luckily I can use VLC locally as a more stable alternative.
We’re all hoping for the same fix, have a nice day.
Fantastic news, are give it a shot when I turn on my server and if sound are mark it as solution, many thanks have a nice day.
Can confirm this issue is fixed, thanks plex.
