Replaced hard drive. Now what?
Hi first time posting here and not sure if posting in correct place.
I’m hoping someone can help.
I recently had a problem with my win 10 not booting (Blue screen of death).
I decided to replace and upgrade my SSD and reinstall win 10.
How do I now reinstall PLEX correctly and/or easily?
Mind you I did not properly quit PLEX on my previous hard drive.
Since the Plex data folder is located by default on the drive C:\, all your Plex data are gone now.
You will have to install Plex completely new, but make sure to use your existing plex.tv username, email address and password.
You should remove the authentication token of the old server from your plex account: https://app.plex.tv/desktop#!/settings/devices/pms
Got it working. Thank you so much!
