Replacement Server and UNO Headaches
Hi guys,
Long time plexpass user here. I recently deleted my old ubuntu vm that was running my plex server for years. I switched to Unraid and created a new VM and installed plex server, claimed it and started scanning my files.
The issue is when I log Launch plex now from plex.tv It only shows me the default web shows, on deck - podcasts etc. The usual home screen that im used to is gone. I have to click “more” to even find the new server.
Does anyone know how I can get the recently added (movies, TV shows, etc) and continue watching sections back on my home screen?
Here’s the guide to customizing Plex in the new UNO design. Make sure the hubs you want are enabled on your home page, and then make sure the libraries you want included in those hubs have the “Include in dashboard” advanced option enabled.
Since you have a new server, you will have to re-populate your home page and side bar with libraries and hubs from this new server.
This will set you up quickly:
Settings - Web Client - General - ‘Show Advanced’ - “Reset Customization”
You can then go from there and refine things, using this guide:
https://support.plex.tv/articles/customizing-plex-web/
Make sure to have only one web browser tab/window with the web app open, while doing the above.
Reset customization did it. I have my "continue watching ", and “recently added” back.
Thank you both!
