Replacement suggestions for my server?
So I’ve been using an older Macbook pro as my server for quite a while. It’s tool old to update to 10.8 though, so I can’t get the latest version of PMS. So now, I can’t access my server on the mobile app, and I have to connect directly with the web app which is annoying.
I guess I’ll finally have to bite the bullet and upgrade my server. What are some good low-cost options I should look at? Just doing local streaming, my internet at the house is too slow to bother with away from home.
Build a budget PC, make sure the case has room to fit more HDDs. What kind of price are you looking at?
