Request-Let default be on "Library" setting instead of "recommended" setting
Please allow option to have a default of what screen goes to when going to media section. Currently, when you click on movies or tv shows, you land on “recommended” section. I would prefer that it goes to “library” section by default.
There is a preference setting that will make it stay on the last thing you picked. Not the same thing, but at least it’s available now.
Except this setting does not work. It re-sets every time there is an update…which is often. Nearly every time I open PLEX on either my iPad or iPhone, every media section has been switched to “Recommended”.
I would prefer to remove “Recommended” altogether from my server for myself and my users…barring that, I should be able to set the default to “Library” instead.
Upon reflection, I should just file this as a bug report. The selected tab should be remembered across upgrades.
