I recently added a whole bunch of concerts/festival sets to my Plex library. I would love it if a metadata agent existed to pull the setlist from setlist.fm & add it to to the summary text.
Eg I have a file “Ellie Goulding - Coachella 2014.mkv” it should match to this http://www.setlist.fm/setlist/ellie-goulding/2014/empire-polo-grounds-indio-ca-4bc39382.html
Nice request but no answer.
Yeah its a shame no one is interested. Still wishing I didn’t need to add it all manually.
Such a functionality would be amazing.
Would love this!
There is an API for this site supporting json (easier) and XML so it is doable: https://api.setlist.fm/docs/1.0/index.html
- unique setlist id like: 4bc39382 assigned by the search() function
- support poster
- track list (if movie agent use to put as summary)
- use location to set tags
- date
You have a single video file so you may want a movie agent and a series agent if the separate tacks were split in multiple files.
You could set the artist as a tv series, then the year as the season for example…
I would recommend labeling in GitHub the project “Setlist-fm.bundle” and doing a movies+tv series agent possibly.
- You can find an empty metadata agent template here for series https://github.com/ZeroQI/Hama.bundle/releases/download/v1.0/Empty_Agent_template.bundle.7z
- If you look at the Hama agent link in my signature you can have a single agent for movies+series
- Agents are written in Python and json might be the easiest, you can progress by finding another json based agent like https://github.com/lankz/JSON.bundle/blob/master/Contents/Code/init.py or
- Plex development guide is located here: /uploads/default/original/3X/c/4/c474c361f240cf9ffd7330481c995a38c7d32a5b.pdf
