Managed to sort this out in a bit simpler way, in case you have a QNAP NAS: https://forum.qnap.com/viewtopic.php?f=358&t=166612&p=825888#p825888
If you look in the script, That’s exactly what it does at the end.
The rest of what it does is to make sure Preferences.xml is UNCLAIMED so you can reclaim it because not everybody is that comfortable messing around with the editor and paths. ( There are a lot of Linux noobies around here )
AND
It works for a bunch of different environments.
Hi @ChuckPa ,
first, sorry for my late reply here, i got sick and couldnt test it sooner.
Then in addition, HERE is one of your mentioned Linux / SSH Noobs out there
never touched Putty or so any time before.
It DAMN WORKED MAN!
Absolutely great - you deserve every cold brewed and yummy pizza you can get buddy ![]()
Thank you again, i hope it will work for longer now.
If i encounter any issue i will report of course but for now it seems awesome ![]()
Have a great day ![]()
Cheers, Mantok
