Resolution Banners on Movie Posters
Would it be at all possible to add banners to the movie posters with the video resolution…
even if it’s just something like SD/HD/UHD…
I am curious what you are trying to accomplish here. you can use filters and one of the options is resolution. its also my understanding that Plex can handle multiple resolutions of the same movie.
It would be nice to have a banner on the movie poster so you can see at a glance what type of movie it is without having to use filters or open the movie info…
It does handle multiple resolutions of the same movie… by flagging them as duplicates… instead of a separate entry with a different banner…
