Hi Guys & Gals,
I am currently running into a problem where any media that uses EAC3 causes a permenant buffer and fails to play.
I know there are already many threads going back several years related to this problem, but I am unable to resolve the problem using multiple suggestions in previous threads.
Error Example:
Dec 08, 2019 22:09:23.001 [0x7f3c59ffb700] Error — [Transcoder] [eac3_eae @ 0x190bf40] EAE timeout! EAE not running, or wrong folder? Could not read ‘/tmp/pms-3d96690b-8fc0-4bd4-ae24-72d7c36fb807/EasyAudioEncoder/Convert to WAV (to 8ch or less)/00ur6ce7v8ui7peqjpf91fhk_1677-0-25.wav’
Dec 08, 2019 22:09:23.002 [0x7f3c0affd700] Error — [Transcoder] [eac3_eae @ 0x1c53f40] error reading output
Dec 08, 2019 22:09:23.003 [0x7f3c417fa700] Error — [Transcoder] Error while decoding stream #0:1: Input/output error
OS: Ubuntu 16.04.6 LTS
PMS: Version 1.18.2.2029 - Base (Not running on the PMS Docker Image?)
Attempted fixes include:
Rebooting Server
Updating OS,
Updating Plex Server,
Delete Codec folder under /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs,
Creating a new directory and pointing the transcoder to the new location, (REVERTED TO DEFAULT)
Running chmod 777 EasyAudioEncoder under /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/EasyAudioEncoder-334-linux-x86_64/EasyAudioEncoder,
Is anyone able to tell me where Im going wrong here?
Its worth noting that this used to work, and no changes were made manually by myself between the last known good config and since errors have appeared.
Im guessing an Ubuntu update of some sort may have thrown a spanner into the works here given I run auto-updates and this would have been the only changes that took place.
Any advice would be greatly appreciated, let me know if you need any more details.
Thanks.
