Server Version#: 1.13.6.5339-115f087d6
Player Version#: n/a
I have been keeping my plex media server data on a separate network drive, and had to change the drive, and the drive letter.
I have kept the data folder, but could anyone tell me the correct steps for restoring from this please?
I have uninstalled plex from the pc it was on, and I can install fresh, but when I point the data folder location to the correct (mapped) network drive, it then fails to open. I’m sure there’s something silly I’m missing
That is a bad idea. Plex uses a database to store a lot of the info and this does not work well over networks. You can often end up with a corrupted database, which may have happened to you and why it won’t load now. I would suggest moving this back to an internal hard drive, just to make sure everything is fine.
The problem is its a massive folder now, and I had to move it a few years ago… Not had an issue before now. It’s still on the network, and is a mapped drive
Is there a way to check for corruption? As I said, it does work sometimes.
If it was corrupted and I moved it onto an internal drive, would that fix it?
Let’s assume your database isn’t corrupted. You should technically still be able to point PMS to look at a network drive. Are you using the drive letter or network map in your PMS setting. I assume that when you say you point PMS to the new network drive, you are entering the path into “The path where local application data is stored”.
I never moved the folder, I just had it renamed, so all the folders are exactly as they were before I reinstalled… So yes that plug in support folder is there. Maybe that’s causing me the issue
Can I just close media server, delete the folder, then restart? Does it recreate or something?
