I didn’t see this anywhere, so sorry if it’s a duplicate topic.
I recently had an issue where Live TV on a Roku local device wasn’t working.
I have my server set to “High Quality (30fps limit)”
A HDHomeRun Extend Transcoding to 720p 30FPS.
The Roku device was set to play original quality.
No matter what channel I used, it would stay on 99% then fail. I ended up setting the local quality on the Roku device to 720 and it started playing correctly after that. Not sure where the issue is, just reporting it in case anyone else has this issue.
I’ll take a look when I have a chance to see what is causing the issue.
Why the above Plex/HDHomeRun configuration?
I had previously tested a few Plex/HDHomeRun configurations and saw this was the fastest and the least workload on my GPU. Even though the Homerun is transcoding to 720 already, Plex still transcodes. No transcoding or anything higher will strain my GPU considerably (Nvidia Quadro P2000)
