If you try to resume, fast forward, or rewind the video restarts to the beginning, unless playback is set to disable Or you force lower resolution (of course.)
I haven’t seen this issue often, advanced I saw this was a bug that was mentioned to be fixed, but not in all cases apparently.
I can provide a sample of the video if needed.
I didn’t think logs would be helpful, but let me know and I can include them.
We did have a regression in the past couple months that was fixed related to transcoding (when we had to use a MKV container over HLS).
In your case, it sounds like this only affects Direct Play and transcoding/remuxing fixes the issue.
The usual reason for this seeking issue is due to a container issue. Other players may work around it, but the player built into the Roku is a bit more picky. I’d suggest remuxing one of the affected videos and testing the result. mkclean is an easy solution if you have windows or mac, otherwise ffmpeg ffmpeg -i input.mkv -c copy -map 0 output.mkv should also work just fine.
