Not sure if this should be in Mac or Roku section, but I’ll start here.
When I watch a movie, if I want to rewind or fast forward, it restarts the movie. I imagine this is due transcodes or something and having to start over, but, is there a way around this? It happens when resuming a movie too - or under circumstances where i might want to fast forward past the titles or something.
Is there any place to look at diagnostics in plex? How can I figure out if this is the Roku or my server? Or is it just a software bug?
I’ve noticed the problem is on large movies (i.e. 25GB ones) but not TV shows (2-4GB).
Any help appreciated. Roku and Plex are up to date, latest software.
I have movies that are 64GB in size and do not run into this problem so, I
do not think it’s an issue with file sizes. I will say, I cringe when
rewinding or fast-forwarding movies because of the lag-time to resume.
That’s the only issue I experience.
I can deal with lag, but, this makes Plex unusable because if it restarts every time I change position I can’t fast forward it back to where I was either. So, I’m stuck back at the beginning.
I’ve been using Plex for over 2 years. It’s far from unusable. There are
quirks here and there, but the functionality always resumes and if there
are real bugs, they are addressed in updates along the way. What you are
experiencing is unusual. I recommend you attach logs and we’ll see if
support will pick up on them and look into your issue.
Was watching The Fifth Element for ease of reading the log.
The other logs had nothing during the time I experienced the problems. Really the Plex Media Server Log is the only one with relevant information I could find, the DLNA log just has two entries around the time I was watching them movie.
This happens with some of my mkv files. I don’t know why it happens on some mkv files and not others. However my solution is to use Handbrake to reencode the movie as .m4v. Then replace the mkv with the .m4v and Plex on roku restarts at last stopping point when I resume the movie. FFW and REW will also function normally. Weird thing is, the MKV will play, resume, FFW, REW in the browser on Mac. It seems to be a roku issue.
It seems the issue goes away if I select “Transcode” or “Direct Stream”, the resume bug shows up on Roku devices if I select “Direct Play” (forced to start from beginning)
Is it only larger ones? For whatever reason smaller files seem to work for me.
Hm. I’ve been tinkering with various play modes but seem to get it regardless. I’ll try again changing that. I don’t think I ever use anything except direct stream or transcode though…
Same issue on a WDTV Live. If anything is transcoded, ff/rew works but when “play” is pressed to start at that point, it restarts at the beginning of the movie. I can confirm this issue happens. Also, when doing so the timer on the WD shows 0-5 seconds, not the entire length of the movie.
I have worked around it since I have a WDTV Live and I have now managed to get the profile working so absolutely nothing is transcoding now since it can play anything.
Yeah, that alone is reason enough to use the optimiser feature and get direct play. I just wish we could set it to transcode in better quality than the realtime transcoding…
I am having this issue as well (Plex on Roku). Direct Play presents the problem with not being able to seek (fast forward, rewind, instant replay), but disabling Direct Play and using Direct Stream allows seeking. The MKV plays fine in VLC and even WMP. According to Tautulli, the Direct Stream is still transcoding the container (Transcode (MKV > MPEGTS)) even though the video and audio streams are unmodified. Playing via Plex Web resulting in a transcode of the audio stream to stereo, so I can’t accurately test Direct Play via Plex Web (at least for this given movie) currently.
Same issue here on my roku3. Didn’t start until the new update. Also on plex my videos stop after about 20 minutes and causes the roku to reboot itself. Great update.
Same issue for me on my Sharp Roku TV, shows restart when fast forwarding. Videos are .TS format, recorded from antenna through the guide. I tried tinkering with other stream settings but direct play is always smoothest and fastest. My mkv movies work fine though.
Trying to watch football recorded to Plex has pointed out to me that Plex is still a lousy DVR. I pay for Plex to have a stable product. Currently and after finding this thread is seems that for a long time FF/RW with Auto then I get a 10 second buffering and if I use Forced Direct that play starts instantly but Roku supports direct play from SiliconDust HDHR but Plex cannot support Force Direct HLS (whatever that is) but take 10 second to buffer unless direct play is set to force. I think I need the free version of Plex and a DVR from the cable company. It’s a shame when Cox provides a better solution.
[quote=“diveatlas, post:1, topic:221581, full:true”]
Using the DVR to record shows, but skipping forward later in the show or simply fast forwarding does not work. Lets say I am at the 5 minute mark. I can bring up the fast forward interface and go out to say the 20 minute mark, but when I push play it just goes back to the 5 minute mark. Anyone out there able to fast forward a show recorded using the DVR?
I can’t fast forward or rewind using plex DVR. Makes it totally useless since the commercial on OTA are about 15 mins per 30 min program. I see this has been an issue with ff and rewind for 4 years? lmao
