I have 2 Roku TV’s, 2 Roku sticks, and 2 Amazon Fires. Just installed a new server on Windows machine and it appears to working correctly on all TVs but one Roku TV (previous server was on a Mac but the new Plex app requires the PMS to run 1.10.0 and my Mac is too out of date to run that version!). I have compared the setting on everything and they are all set up just alike. The one that won’t work sees the PMS but it keeps saying “unavailable”. I have logged out, restarted the TV, verified the port…I don’t know what else to do! Any suggestions?
What is your servers “secure connections” set to? What is your Rokus “allow insecure connections” set to?
Roku set to “Allow Insecure Connections - On Same Network”
PMS “Secure connections – Preferred”
yeah those are correct. Can we see the Roku logs.
Where do i find the logs? This is crazy! I just hooked a Roku stick in an empty HDMI port and it works just fine! It actually sees both servers!
found the logs. what do i do now.
Copy to a text file if not already. Then just drag and drop the file on in the text entry reply window.
You sure you want all of this…?
Roku Logs.txt (24.2 KB)
yes please thank you. If you can please put it in a text file next time. (I put it in one for you).
looking it over
Plex Media Scanner.log (3.8 MB)
Uploading: Plex Media Scanner.1.log… Plex Media Server.log (2.4 MB)
Uploading: Plex Media Server.1.log… com.plexapp.agents.localmedia.log (17.8 KB)
Uploading: Plex Media Scanner.2.log… Uploading: Plex Media Scanner.3.log… Uploading: Plex Media Server.2.log… Uploading: Plex Media Scanner.4.log… Uploading: Plex Media Scanner.5.log… Uploading: Plex Media Server.3.log… Uploading: Plex Media Server.4.log… Uploading: Plex Media Server.5.log… com.plexapp.agents.imdb.log (24.3 KB)
com.plexapp.agents.themoviedb.log (9.7 KB)
Plex Media Scanner Chapter Thumbnails.log (160.5 KB)
Plex Transcoder Statistics.log (1.0 MB)
Plex Transcoder Statistics.1.log (285.7 KB)
Plex Transcoder Statistics.2.log (275.5 KB)
Plex Media Scanner Deep Analysis.log (6.7 KB)
Plex Media Scanner Chapter Thumbnails.1.log (6.3 KB)
Plex Media Scanner Deep Analysis.1.log (8.6 KB)
Plex Media Scanner Chapter Thumbnails.2.log (5.2 KB)
Plex Media Scanner Deep Analysis.2.log (16.4 KB)
Plex Media Scanner Chapter Thumbnails.3.log (6.3 KB)
Plex Media Scanner Deep Analysis.3.log (5.5 KB)
Plex Media Scanner Chapter Thumbnails.4.log (4.3 KB)
Plex Media Scanner Deep Analysis.4.log (9.5 KB)
Plex Media Scanner Chapter Thumbnails.5.log (4.0 KB)
Plex Media Scanner Deep Analysis.5.log (5.9 KB)
Plex Media Scanner Analysis.log (20.7 KB)
com.plexapp.system.log (917.4 KB)
Plex DLNA Server.log (13.7 KB)
Plex Tuner Service.log (1.2 KB)
Plex DLNA Server.1.log (19.9 KB)
Plex Tuner Service.1.log (1.2 KB)
com.plexapp.agents.lyricfind.log (4.9 KB)
com.plexapp.agents.movieposterdb.log (4.8 KB)
com.plexapp.agents.none.log (14.7 KB)
com.plexapp.agents.opensubtitles.log (6.7 KB)
com.plexapp.agents.plexmusic.log (7.7 KB)
com.plexapp.agents.plexthememusic.log (5.0 KB)
com.plexapp.agents.thetvdb.log (4.9 KB)
Plex Transcoder Statistics.3.log (1.6 MB)
Plex Media Scanner Analysis.1.log (71.4 KB)
Plex Media Scanner Analysis.2.log (86.0 KB)
Plex Media Scanner Analysis.3.log (67.1 KB)
Plex Transcoder Statistics.4.log (240.7 KB)
Plex Media Scanner Analysis.4.log (2.0 KB)
Plex Media Scanner Analysis.5.log (2.5 KB)
Plex Transcoder Statistics.5.log (705.0 KB)
com.plexapp.agents.lastfm.log (7.3 KB)
com.plexapp.agents.htbackdrops.log (7.2 KB)
com.plexapp.agents.fanarttv.log (12.1 KB)
Plex DLNA Server.2.log (1.8 KB)
Plex Crash Uploader.log (525 Bytes)
Plex Crash Uploader.1.log (557 Bytes)
Plex DLNA Server.3.log (84.9 KB)
Plex Crash Uploader.2.log (521 Bytes)
Plex Crash Uploader.3.log (557 Bytes)
Plex DLNA Server.4.log (14.4 KB)
Plex DLNA Server.5.log (8.6 KB)
Plex Crash Uploader.5.log (521 Bytes)
Plex Update Service Launcher.log (706 Bytes)
Plex Update Service Launcher.1.log (706 Bytes)
Plex Update Service Launcher.2.log (706 Bytes)
Plex Update Service Launcher.3.log (992 Bytes)
Plex Update Service Launcher.4.log (706 Bytes)
Plex Update Service Launcher.5.log (706 Bytes)
is this correct? the last i opened in “notepad” and copied and pasted. this time i dropped the files in…
