Roku Ultra Wired Buffering Error
When using the plex roku app I keep having buffering errors. I have it connected as a direct ethernet connection. Roku speed test reports an internet connection speed of 76mbps.
Anytime I attempt to stream from a remote server the stream begins to buffer and spin after a few moments it plays again and again buffers.
I was able to play a local video stream with no issue. I do have it set to play at original quality at the request of the server owner.
After a few cycles the message “Playback Error Your connection to the server was not fast enough to stream this video. Check your network or try a lower quality.” Internet speed should be zero issue since we have a 500+ Mbps package.
Why could I send logs to, I have them saved from the roku.
are these 4K files??
if they are remuxes then you are still going to have some issues no matter how fast the network is because Rokus only have 100mbit ports and 4k remuxes have extremely high bitrate spikes that will create issues…
while playing the files ask the owner of the server in question to look at what the dashboard is showing…
