Rotate video
Some videos on older cell phone models and even new ones if taken with screen lock on, can often lead to the incorrect orientation. if the ability to rotate was easily available , it would be a very simple and helpful option
Il suffit d’interpréter correctement les MEDIAINFOS pour en déduire s’il faut appliquer une rotation. Cela fonctionne jusqu’à HD1080, mais au dela (2K, 4K, …) cela ne fonctionne plus. Merci de corriger ce bug
It is enough to correctly interpret the MEDIAINFOS to deduce if it is necessary to apply a rotation. It works up to HD1080, but beyond (2K, 4K, …) it does not work anymore. Thank you for correcting this bug
