Routine drops in playback performance - visible FPS dropping
I am getting stuttering (appearance of FPS drops without any accompanying audio issues). The videos will play without issue for usually around 10-20 minutes, and then there will be a noticeable drop in fps with choppy movement that can last from 10-60 seconds and then will resume playing without issues until it happens again later. Usually pausing and playing will temporarily fix the issue until another 10-20 minutes goes by and it will happen again. Through the course of a 2 hour film, it happens routinely enough that it’s quite annoying.
I have been focusing on 24p (23.976fps) videos in trying to fix this since it’s particularly noticeable due to the already low frame rate. However, I have a sense that it may be impacting beyond 24p.
  • Windows 10 64bit fully updated
  • Intel I7 7700k
  • RTX 2070super fully updated drivers
  • Plex for Windows latest 1.40.1.2823-6f60f3a7
  • CPU/GPU is nowhere near 100% during playback
  • In the past I’d been using Smooth Video Project with Plex until recently when I stopped so I am not exactly sure when the issue might have shown up since SVP possibly hid this issue.
  • Plex Web in Chromium might be unaffected after some testing.
The following I have tried without success:
  • Plex video processing set to low or maximum quality
  • Matching monitor refresh rate to video (23.976hz exactly)
  • Two different displays present the same issue (monitor/projector)
  • TV display “film mode” on/off
  • Windows Variable Refresh Rate (VRR) turned on/off
  • Windows Hardware GPU Scheduling turned on/off
  • NVIDIA profile for plex set up with low latency off, vsync on, power adaptive, gsync off
  • G-sync fully turned on/off
  • Different configurations of mpv.conf including (video-sync-display-resample and interpolation=yes)
  • Software and hardware decoding
  • transcoding on/off
  • h264 and h265 files
Can anyone (or a developer) please let me know on any of the following:
  • Have I missed something in trying to fix the issue?
  • Is this simply ‘24p judder’ that I’m reading about and something I can’t fix? Strange that it will play very smooth for so long until the poor performance shows up. I am under the impression that 24p frame rate issues should be more consistently present if noticeable.
  • Is this a Plex codec issue?
  • Does Plex for Windows use MPV’s interpolation and video-sync-display-resample by default to help alleviate display/audio sync issues due to mismatched clock rates?
Thank you very much!
I have narrowed the issue down to the NVIDIA GPU.
I have submitted a ticket with NVIDIA support.
Here is the text from my ticket to clarify:
I have spent a lot of time narrowing down an issue regarding 23.976 refresh rate and playing videos smoothly.
I have determined that with this NVIDA GPU, setting the refresh rate to 23.976hz on an HDMI monitor and projector and playing a video of the same rate (23.976) on different video players (MPV, Plex, MPC-HC) yields stuttering playback, usually after a period of time - up to 6 minutes where the visual performance will drop for a period of time where it may recover until it happens again. Pausing and playing temporarily resolves the issue. Over the course of a movie, it might happen 10 times or more.
The player logs don’t report any issues or dropped frames, however the FPS performance drop is quite noticeable. So it appears the issue is happening after video processing and on transport to the display.
I have tried turning off GSYNC, VRR, disconnecting all displays but primary and many other troubleshooting steps without success.
However, if I switch the display to the iGPU (Intel HD Graphics 630) the issue is completely resolved.
I have noticed that the iGPU as well as the iGPU on a laptop (both Intel-based) report a slightly different array of refresh rates for the display than the NVIDIA GPU does, if that is relevant at all.
It appears that there is a timing issue with the refresh rate. I can confirm that windows display settings shows the Intel GPU and the NVIDIA GPU both set to exactly 23.976hz so it isn’t clear how there could be a timing issue specifically on the NVIDIA GPU.
If my goal was more frames I would do the opposite: low latency ON and vsync OFF.
Although they both sound like 3D settings. May not affect 2D output at all. It’s worth trying however.
Thank you for your response.
Unfortunately this did not solve the issue.
