Greetings! I have a seagate 8TB portable hard drive. With tons of tv, some music, and 1300 movies, I am running out of storage. Can I buy a second 8tb hard drive and just assign the same letter? Or, if I choose to name it another drive letter, can Plex recognize two different hard drives? Thanks in advance.
Plex doesn’t care where the media is stored. When you create the library, you tell it where to look. If you add another storage location, add that to a Library section, move media from one drive to another, PMS won’t care.
The full procedure is here. https://support.plex.tv/hc/en-us/articles/201154537-Move-Media-Content-to-a-New-Location
Goodness, Chuck. Thank you for such a fast reply.
I probably did not explain my issue correctly. ( I do understand the instructions you gave and I have followed them when I previously upgraded my portable hard drive to increase its size.) My issue is that I want to have TWO different hard drives at the same time… each at 8TB. I have nearly filled up one 8TB hard drive and I want to keep that media on my first hard drive and ADD ANOTHER 8TB hard drive… so that I have a total of 16TB, not 8TB. I don’t want to replace one 8TB hard drive with another 8TB hard drive.
I would like to use TWO different 8TB hard drives for a total of 16TB for my server. (The reason for two is that I already have one 8TB hard drive and to add another, that would costs under $200. To buy a single hard drive with 16TB would set me back a whopping $500.)
So, can I have TWO hard drives that share a drive letter? I know it is physically possible, but will PLEX handle that? If I have TWO hard drives each with a different drive letter, will Plex even allow me to do that?
Is there a solution other than having to spend $500??
Thanks again.
Ah, then I misunderstood your question. You want to know if you can upgrade the internal storage HDs .
As I understand Windows. You install the new HD, format it and assign a drive letter.
As example,
D:\Movies (the original)
E:\Movies (the newly created one with a `Movies` directory you just created)
All you need do is Edit your Movies Library section and Add folders. When you Browse for Folders, add E:\Movies to the list. Save the changes
It’s that painless. PMS will do the rest of the scanning automatically. To PMS, it’s a list of media sources.
Now, you can move things around from D → E.
Is this what you want to do?
LOL, Chuck. It is me, not you. I “think” understand your answer though… so I am getting closer at being able to articulate myself ;).
1) I want to keep all media I have on D:/. I do not want add anything more to D:/ (because I have run out of room! ;))
2) I then want to add ANOTHER hard drive so that I have more room to add more media.
Are you saying I can keep all current my media on D:/, then add a folder to my library on D:/ and assign E:/ to that folder?
So, library is assigned to D:/ and then within that library is a new folder that I can assign to my new E:/ drive??
Thank you for your patience.
Moderator Edit: “Code” paragraph formatting fixes many evils >:)
drat! All those frowny faces are D drive.
I am saying:
- After you add the next drive (
E:\) - Create a
Moviesdirectory on it (or whatever you need) -
Editthe appropriate Library section and tell PMS to look inE:\Moviestoo for movies - You can move stuff OFF
D:\Moviesand over toE:\Movies
PMS won’t care. Just remember to Update Libraries after you’ve done everything and it hasn’t been following along (Automatically update my library as changes are detected in Settings - Server - Library)
Thank you, Chuck. I appreciate all your help. I think I understand what you are saying. I will play around with that a bit later to see if it will work for my needs.
You just plug in the NEW drive give it a letter then goto Plex as you did originally and add the new drive.
So now in Plex you will have it pointing to e.g. d:\movies AND E:\movies ?
does that make sense?
YESSSS!!! Thank you, Chuck and spikemixture. I tested out what you both wrote and it works. Thank you for saving me $$$.
Do you need the drives to be cloud drives? I have one Seagate cloud drive which runs plex amazingly well. I’m looking at getting a second and splitting my library. Just wondering if it matters what kind of second network drive I get. Thanks
In short no it does not matter.
