Running plex connect on Multiple Apple Tv's
Scenario
Mac pro as the PMS (connected by ethernet)
Asus dark night router
Living Room Apple TV (connected via ethernet to Asus Router)
Plex connect set up and works fantastic in the living room.  (unable to connect to plex server wirelessly from the bedroom)
Using the same plex connect DNS settings for the living room for the
Wirelessly connect apple TV does not connect
Any suggestions.
I tried searching through the previous postings all I could find was that members were able to run multiple apple tv's
Thanks!
I use multiple appletv’s all using the same iMovie cert. I use a Mac as a pms server and can connect my atvs using Ethernet or wifi. Start by posting a log following these guidelines lines for everyone to help you as fast as possible:
https://github.com/iBaa/PlexConnect/wiki/How-to-report-an-issue
