Hi!
I Have 2 apple tv (ethernet) connected to a pc running windows 7. The first one runs perfectly. The second one will work fine for a while (minutes or hour) than begin to buffering a lot or disconnect and return to the apple tv menu. I have switch them, same problem (at the same emplacment, not on the same apple tv…) We rarely use plex one more than one device at the time.
I have try wireless, same problem.
Plex is also running perfectly on two Western digital tv live.
I’m very frustrated, if someone has a clue it would be so great…
Thank you.
