Saga/licence sorting
Hi !
I was wondering that a categorie dedicated to a licence should be good.
Per exemple, if I want to group in the same categorie, films and series from Star Wars I can’t. I have to create 2 categories. One with the movie type and another one with TV Series.
My « new » type would allow us regroup on the same categorie Movies and Series to avoid to get 2 categorie for the same licence.
I know I can do collections but I feel it unconfortable and messy.
Thanks :slight_smile:
I’m not sure I fully understand what you’re asking for.
I assume you’re asking for an option to have libraries that can contain both movies and tv-shows?
This has already been asked before… so if this is your suggestion, I recommend you comment/vote in that other thread in order to avoid distracting/dispersing votes.
If you’re asking for something else… can you please rephrase your suggestion?
I make playlists to sort chronologically and combine movies and series in one place (for example “Marvel Universe”, “Star Wars”, “DC Universe”). I hope it helps you until Plex implements a solution.
Yo hago listas de reproducción para ordenar cronológicamente y combinar películas y series en un mismo lugar (por ejemplo “Universo Marvel”, “Star Wars”, “DC Universe”). Espero que le sirva de ayuda hasta que Plex implemente alguna solución.
Hi, i didn’t see this topic thank you !
I am French so my english isn’t perfect ^^’
Really smart ! I’m going to try this ! :slight_smile:
