Same poster for multiple shows?
Let’s say I add 200 episodes of a show. Can I easily add one poster and all of them use it?
https://support.plex.tv/hc/en-us/articles/200220717-Local-Media-Assets-TV-Shows
Scroll part way down the page, you’ll see the section for Artwork
Please explain a bit more.
Is this a ‘custom’ show which doesn’t appear at TheTVDB or TheMovieDatabase?
Normally, Plex will fetch episode thumbs from there automatically.
Or do you want to override those automatic thumbs with your own, custom pictures?
If so, I’m afraid you will have to supply a fitting poster for every individual episode.
Heroes - s01e01 - Genesis.mp4
Heroes - s01e02 - Don't Look Back.mp4
didn’t really see what I was looking for in there right off hand. . .but i found that if i merge them all together, assign a poster and them split them, the poster stays with each episode, so that works!
:smiley:
Nice “hack”!
right, i wanted to replaced episode thumbs with a single image for all shows. . . .and i figured out the merge and split thing mere seconds after i posted my question :slight_smile:
