Samsung q60t 4k movie buffering
Server Version#: latest
Player Version#: latest
on new samsung q60t plex player buffering video every 2 min then i play 4k movie
can you look at the logs and tell me what the problem is?Plex Media Server Logs_2020-05-28_12-52-28.zip (470.5 KB)
Does the same thing happen when you play 1080p material? I have a q60t that can’t handle any stream over 4Mbps.
1080 play without problems.
but 4k rip (50gb) with ac3 audio (without trancodding) start 2 sec buffering every 1~3 min.
tv connected with router by wire.
I can play with no problem using the embedded browser, but the embedded Plex app has problems. You might try seeing if you can play 4K titles with the browser.
Is this your reddit post? https://www.reddit.com/r/PleX/comments/grik69/samsung_q60t_client_chokes/
It mentions browser playback works, but I believe that it would work if it was transcoding. Could you confirm that? I checked your logs but there isn’t much to go by there. Could you generate a new set of logs by playing a video that works, and then a couple videos that has issues? Preferably of different containers and codecs?
This is not my post.
I did not check the playback of problem files through the browser.
Attached new logs. And I want to ask you why there is no latest version of Plex in a smart hub?
Latest version on my tv 4.21.2 but new ver out 14 days ago Plex for Samsung (2016+ UHD televisions)
Samsung support answear me, then new ver. 4.25.2 not adopted for tizen 5.5
How to install the latest version?
Plex Media Server Logs_2020-05-30_13-35-28.zip (1.1 MB)
