I have kill stream enabled for my server via Tautulli if video decision = transcode so I have users set there plex clients to maximum under remote.
One of my friends streams on a Samsung tv via Tizen, even though he is setting to maximum remote play with direct play enabled his streams are still being killed due to transcoding.
Here is the log;
Dec 23, 2019 20:36:11.639 [0x7f3d567fc700] DEBUG - MDE: Selected protocol dash; container: mp4
Dec 23, 2019 20:36:11.639 [0x7f3d567fc700] DEBUG - MDE: analyzing media item 4191
Dec 23, 2019 20:36:11.639 [0x7f3d567fc700] DEBUG - MDE: The BFG (2016): Direct Play is disabled
Dec 23, 2019 20:36:11.639 [0x7f3d567fc700] DEBUG - MDE: The BFG (2016): media must be transcoded in order to use the dash protocol
Dec 23, 2019 20:36:11.639 [0x7f3d567fc700] DEBUG - MDE: The BFG (2016): selected audio stream is not the first audio stream and direct play stream selection is not enabled
Dec 23, 2019 20:36:11.639 [0x7f3d567fc700] DEBUG - The BFG - video.bitrate limitation applies: 9796 > 4000
Dec 23, 2019 20:36:11.639 [0x7f3d567fc700] DEBUG - MDE: The BFG (2016): no remuxable profile found, so video stream will be transcoded
Dec 23, 2019 20:36:11.639 [0x7f3d567fc700] DEBUG - MDE: Cannot direct stream video stream due to profile or setting limitations
Dec 23, 2019 20:36:11.639 [0x7f3d567fc700] DEBUG - Scaled up video bitrate to 14694Kbps based on 1.500000x fudge factor.
Dec 23, 2019 20:36:11.639 [0x7f3d567fc700] DEBUG - Scaled maximum bitrate for resolution reduction to 6512Kbps.
Dec 23, 2019 20:36:11.639 [0x7f3d567fc700] DEBUG - MDE: Cannot direct stream audio stream due to codec dca when profile only allows aac
Dec 23, 2019 20:36:11.639 [0x7f3d567fc700] DEBUG - MDE: The BFG (2016): selected media 0 / 4191
Dec 23, 2019 20:36:11.639 [0x7f3d567fc700] DEBUG - Streaming Resource: Adding session 0x7f3d14222d30:mnmigc11ylg8f10zs4ojjys8 which is using 3990kbps of WAN bandwidth. Used is now 10003990kbps
I don’t have any limitations set apart from 2 remote streams.
