Samsung TV Cannot Connect to Plex
@Orca
Thank you to still behind with us and for all your great works
well done ! this collaboration with @plex_tyrael_metaname_de
tried both proxies and all working smoothly.
Dear @plex_tyrael_metaname_de , do you mind to post a docker release from your proxy4plex ?
have a nice day !
indeed, i can do that. as soon as i have some free time (maybe next weekend) i will provide a docker-image on the hub.
It all works flawlessly on my 2012 model, with the proxy on a Synology docker (no special parameters required).
Installing the plex app package with SammyWidgets indeed requires for the archive to be zipped without a “plex” folder, as indicated above by sanelyidle, but it is all very straightforward otherwise.
Well done and thanks, from Belgium.
FWIW, I got my app working again by changing Plex server’s network connections to “Preferred” and removed the checkmark next to "Disable weak TLS versions ". In Orca’s V.2013 app -->preferences -->system signed out of Plex account and disabled secure connections and manually added the lan server IP to “my Servers” tab.
Samsung 3D 2013’ model UN60F8000
Plex Server V. 1.22.2.4282 and up to date as of today
Rechecked to make sure everything working after updating today.
Thanks Orca for making this app.
Was a docker version released? I tried searching for proxy4plex and kadrim but couldn’t find it.
At last,
After several months I must connected an USB Drive to my Samsung SmartTV 2012 Eseries to watch any content with Plex, now all my problem has done with this solution. I installed the new @Orca 's Plex for Samsung 2.014 in two of my 2012 SmartTV. And it working flawlessly. Use this method to install the new Plex for Samsung SmartTV model 2012. And you guys will never need any USB drive again. Thanks @Orca, Thanks @plex_tyrael_metaname_de !! :vulcan_salute: :vulcan_salute: :vulcan_salute:
Thanks for this, i just followed your process, when installing via sammy widget, it loads then comes up 'failed to install, for more information please visit samsungdforum.com/spport/tvappssecurity.
Just wondering…if theres a fix for that step…
Thanks in advance!
Hi Scotty,
I had try to install new Plex for Samsung from @orca with Sammy Widget, but never succeed. It always show “Failed to Install” error message. But when I try the Proxy server method I mention the link above, the installation working flawlessly in the first try. I repeat the process with my other Samsung SmartTV 2012 model in my bedroom. And again, it working with a charm. Maybe you should try the Proxy server method.
Regards.
good to know the automatic install is working for you.
if anything happens, just post an issue over at the github-project:
currently i have no active development as everything seems to be working alright. if that changes, please open an issue. thx!
of course you can also open an issue if you think a new feature should be added :slight_smile:
