Server Version#: 4.76.1
Player Version#: All in Web
Tuner Make/Model: MEGA SAT 2000
Using XMLTV?: No
Have been unable to get SAT>IP service working in Plex on Docker (Unraid). Had this working fine on a stand-alone Plex on Windows, so know services works (and tuner etc) but will not work on docker.
All other Plex functionality is working fine…
Channel scan is sucsessful and am able to map all channels but cannot view anything… get “Playback Error, could not tune channel. Please check your tuner or antenna”
I suspect there is a network related issue… Docker Network is in host mode… UDP Ports 1900,32410,32412,32413,32414,32469 and TCP 32400,32469, 8324 all forwarded to container…
I suspect a multicast problem as i beleive the streams from the SAT>IP use this.
Maybe container does not receive the multicast… just guessing.
Any docker / plex experts have any idea how i might fix this?
