Saving Artist artwork (artist.png?) locally
Not sure if this is the right place for this, but I can’t find a solution.
Is there any way to save the artist artwork locally on my windows 10 desktop? I’ve had to transfer my library a couple times to new desktops and I’d like to keep the setup I have now?
Thank you. May your days be magical.
Hmmm. The weird thing is I have 2800 artists folders and 1900 have an artist.png file in them now. I have not created any of them. So, it looks like something is happening. They are all 300x300. Any thoughts?
That’s definitely not Plex. Either you are using another media software or have installed some 3rd-party plugin into Plex.
Plex should recognize artist photos with the file name artist-poster.jpg. If it doesn’t, that’d be a bug AFAIK.
Perhaps Subsonic/madsonic? The only other media software I’ve used on this box is itunes and musicbee which I don’t believe store artist info.
@trumpy81, no, I haven’t nor is it now.
You can also try LAMBDA
Awesome man this looks like exactly what I want!!
Thank you!
