Saving queue as playlist & shuffle button issues
I have latest version of Plexamp on Android (3.4.7) and two quick questions regarding queue I’ve seen one of these come up in s now closed topic, but they are nagging me so I want bring to them up again.
  1. Is it possible to save a queue in Plexamp Android as a playlist? I don’t see how to do this. I’ve played a playlist I listen to on my drive to work every day so it’s in my queue. I’ve been adding new songs to it over the last week. I don’t especially want to have to go and then add them to the playlist. It would be easier to just save the queue I have now as a new playlist.
  2. Does shuffle not work in the queue? If I play a playlist, I recall it working. If I add one album to the queue, I believe I can enable shuffle. But, it seems like now the shuffle button is always disabled since I’ve added a playlist to the queue and then appended a bunch of random tracks from various artists to that queue. Not sure if this is a bug or because I appended more songs to the queue that aren’t part of the original playlist. Shuffle should always shuffle. Now all the songs I added are stuck at the bottom of the queue in the order I added them. Not ideal.
Otherwise, I love the continual improvements you’ve been making! Fixed a number of bugs from the past and added a lot of helpful tweaks. Thanks for the awesome music player!
Not yet, but on the list!
It depends if you’ve edited the queue or not; it’s a server limitation based on an old design, we’ll hopefully change it at some point.
