Version 1.30.1.2115-linux
player… plex web
when I try to scan movie poster and info it only becomes one option under agent.
Has been after the last 2 updates as it disappeared
show picture
player… plex web
show picture
What are you trying to do? Is the item you’re looking for not detected? If so could you tell me which movie it is?
OP is probably referring to “Plex Movie” being the sole choice now in “Fix Match”.
i.e. similar to Only Plex Movie Appears as Agent to tag movies
Yes, just trying to figure out why they would need to search using a different agent.
sometimes it does not find the right one and then you have to pick the imdb name and change search options. Now there is only one option and then it does not find certain movies
I think my problem was answered by OttoKerner
