Scanner Bug
Server Version#: 4.146.0
After updated to the latest version, I cannot save the setting with this combination.
It did work with previous version. It’s the only combinantion that alway take poster as the cover rather than the screenshot.
The scanner is using the wrong option.
There are two options for Video Files, you want to use the “Plex Video Files Scanner” with legacy agents.
By using “Plex Video Files Scanner”, the cover will ramdonly pick screen shot instead of poster.jpg which is quite annoying.
You cannot mix the new scanner with legacy agents as they aren’t compatible.
