Have just started using Plex to try to replace my Windows MCE, have been using Plex for a number of years and finally got a Homerun Connect Quadro. Have set up and connected to Plex server which I run on Windows Server 2016, am in the UK and receive 105 Freeview channels. The problem I am having is recording some movies, if the movie is split into two parts in the EPG by a 60 second news item then the EPG shows both parts scheduled to record but in the recordings list it only shows the first part and only records the first part. Have also had a slight problem with some movies where if I select “Movie” in the Add to library then select record the record indicator shows for a second then switches off, if I then try again and select “Other Video” it will record.
Thanks will give that a try, a great example of lateral thinking.
Works as a workaround, just a bit tedious. Sorted the issue about not recording to movie folder, I was trying to record a movie I already have. Thanks for quick response.
