Screenshot
Can you take a screenshot before menu shows up?
Works on my Mac (currently no Windows at hand).
How do you trigger your screenshots? (e.g. [Windows]+[Print] or [Windows]+[Shift]+S)
I do it the standard way.
Windows+PrtScn (or shift+win+s to snip)
Try Alt/Printscreen (grab active window), but I think the menu pops up as soon as you hit the first key.
I was wrong:
Put PMP (Plex Media Player) in TV View (don’t know if that matters - that’s the state mine is in). Put PMP in Full Screen Mode. Alt/Printscreen grabs the full image.
I suspect the ‘Windows’ key triggers the menu, but that’s a wild guess.
I also found a way that works in firefox - ctrl + shift + s then ‘save visible’.
