I used an external keyboard to make a screenshot of plex by typing CTRL+s. Now…I would like to know where are the screenshots stored ?
Hi, Ok but…I put “linux server” as a tag.
What Distor
You talked about GNU/Linux…I talked about rasplex…
Rasplex runs on Linux.
Oh wait. I think I remember something:
PHT was based on XBMC (now Kodi)
And that has/had a screenshot feature. But as I remember correctly, it used to work not or not reliably in PHT.
And I don’t think it was repaired when PHT got turned into OpenPHT/Rasplex.
So no, screenshots are not possible on Rasplex (at least out of the box).
Well, in fact I just checked the bindkey in RasPlex settings and it says “Ctrl+s” is screenshot. Just I just gave it a try. But the things is I heard some “click” when pressing “Ctrl+s” so I guessed it works. But then, I don’t know where to look for the file.
This changes nothing, I’m afraid. Screenshots are a feature of XBMC and were just not disabled when they should have been, during adaption of XBMC into PHT.
Oh…Ok thank you @OttoKerner
