Script to automatically check/update both plex htpc and mitzsch's mpv with TrueHD support
Hi there, thought i share my script to quick and easy check/install latest Plex HTPC and also mpv-2.dll from mitzsch witch fixes support for TrueHD.
###Do not use if you aren’t using mpv-2.dll as mediaplayer for Plex HTPC!###
Its Powershell (works with 5.1 and 7.x) so just run it as admin, might need to check the path to your Plex HTPC install but i use standard so that’s what i set in the script. I use Nanazip to extract 7z archive if needed and the script will check and /or install that if its missing. Do edit the script if that’s not what you are fine with :slight_smile:
###As always, do not run script from the internet if you don’t have the know-how to safely assess if its okay or not!###
This is my current output from the script when executed:
Starting update check for Plex HTPC and MPV…
NanaZip is already installed.
Plex HTPC is up-to-date.
Current Plex HTPC version: 1.65.3.199 same as latest online version: 1.65.3.199
No Plex HTPC update required.
Current MPV version date (from DLL): 2024-07-28
Latest online MPV version: 2024-07-28-6107112
MPV is up-to-date.
No MPV update required.
Update process completed.
Here is the full script, let me know if there are any issues but if you have set $localInstallPath to the correct path i cannot see what might go wrong. Do prove me wrong if so! Will obviously only work on Windows. Laters :slight_smile:
function Get-PlexHTPCFileVersion {
    param (
        [string]$LatestOnlineVersion
    $plexPath = Join-Path -Path $localInstallPath -ChildPath 'Plex HTPC.exe'
    if (Test-Path $plexPath) {
        try {
            $content = [System.IO.File]::ReadAllBytes($plexPath)
            $text = [System.Text.Encoding]::ASCII.GetString($content)
            $cleanText = $text -replace "`0", " "
            $versionPattern = "Plex HTPC\s+(\d+\.\d+\.\d+\.\d+)-[a-f0-9]+"
            if ($cleanText -match $versionPattern) {
                $foundVersion = $matches[1]
                $updateNeeded = $foundVersion -ne $LatestOnlineVersion
                return [PSCustomObject]@{
                    UpdateNeeded = $updateNeeded
                    LocalVersion = $foundVersion
            else {
                    UpdateNeeded = $true
                    LocalVersion = $null
        catch {
            Write-Host "An error occurred while processing the file: $_"
    else {
        Write-Host "Plex HTPC executable not found at the specified path."
function Check-PlexHTPCUpdate {
    $plexExePath = Join-Path $localInstallPath -ChildPath 'Plex HTPC.exe'
    if (-not (Test-Path $plexExePath)) {
        Write-Host "Plex HTPC not installed. Install manually."
        return $null
    $json = Invoke-RestMethod -Uri "https://plex.tv/api/downloads/7.json"
    $download = $json.computer.Windows.releases.url
    if (-not $download) {
        Write-Host "Error fetching data from plex.tv"
        return $null
    $downloadVersion = $json.computer.Windows.version -replace '-.*$'
    $localVersion = Get-PlexHTPCFileVersion -LatestOnlineVersion $downloadVersion
    if ($localVersion.UpdateNeeded -eq $false) {
        Write-Host "Plex HTPC is up-to-date."
        Write-Host "Current Plex HTPC version: $($localVersion.LocalVersion) same as latest online version: $downloadVersion"
        return $null
    else {
        Write-Host "Plex HTPC is NOT up-to-date."
        Write-Host "Current Plex HTPC version: $($localVersion.LocalVersion) is NOT same as latest online version: $downloadVersion"
        return @{
            Download = $download
            Version  = $downloadVersion
function Get-MPVDLLDate {
    $mpvDllPath = Join-Path $localInstallPath "mpv-2.dll"
    if (Test-Path $mpvDllPath) {
        return (Get-Item $mpvDllPath).LastWriteTime.ToString("yyyy-MM-dd")
    else {
        return $null
function Check-MPVUpdate {
    $mpvRelease = Invoke-RestMethod -Uri "https://api.github.com/repos/mitzsch/mpv-winbuild/releases/latest"
    $latestVersion = $mpvRelease.tag_name
    $latestDate = $latestVersion.Substring(0, 10)  # Extract date from version string
    $localDate = Get-MPVDLLDate
    if ($localDate) {
        Write-Host "Current MPV version date (from DLL): $localDate"
    else {
        Write-Host "MPV DLL not found. Assuming update is needed."
        $localDate = "0000-00-00"
    Write-Host "Latest online MPV version: $latestVersion"
    if ($latestDate -le $localDate) {
        Write-Host "MPV is up-to-date."
        return $null
    Write-Host "New MPV version available: $latestVersion"
    $mpvDownloadUrl = ($mpvRelease.assets | Where-Object name -Like "mpv-dev-x86_64-v3-*").browser_download_url
    return @{
        Download = $mpvDownloadUrl
        Version  = $latestVersion
function Update-PlexHTPC {
    param (
        [Parameter(Mandatory = $true)]
        [string]$Download,
        [string]$Version
    try {
        Write-Host "Starting Plex HTPC update process..."
        New-Item -Path $tempPath -ItemType Directory -Force | Out-Null
        $plexFilename = Split-Path $Download -Leaf
        Write-Host "Downloading Plex HTPC update: $plexFilename"
        Invoke-WebRequest -Uri $Download -OutFile (Join-Path $tempPath $plexFilename)
        Write-Host "Extracting Plex HTPC update..."
        & $zipTool x (Join-Path $tempPath $plexFilename) ("-o" + (Join-Path $tempPath "app\")) -y
        $plexProcess = Get-Process "Plex HTPC" -ErrorAction SilentlyContinue
        if ($plexProcess) {
            Write-Host "Stopping Plex HTPC process..."
            $plexProcess | Stop-Process -Force
        Write-Host "Copying updated Plex HTPC files..."
        Copy-Item -Path (Join-Path $tempPath "app\*") -Destination $localInstallPath -Recurse -Exclude '$PLUGINSDIR', '$TEMP', "*.nsi", "*.nsis" -Force
        if ($plexProcess) {
            Write-Host "Restarting Plex HTPC..."
            Start-Process -FilePath (Join-Path $localInstallPath "Plex HTPC.exe")
        Write-Host "Plex HTPC update completed successfully! New version: $Version"
    catch {
        Write-Host "An error occurred during the Plex HTPC update process: $_"
    finally {
        Remove-Item $tempPath -Recurse -Force -ErrorAction SilentlyContinue
function Update-MPV {
    param (
        [string]$Download,
        [string]$Version
    try {
        Write-Host "Starting MPV update process..."
        $mpvFilename = [System.IO.Path]::GetFileName($Download)
        Write-Host "Downloading MPV update: $mpvFilename"
        Invoke-WebRequest -Uri $Download -OutFile (Join-Path $tempPath $mpvFilename)
        Write-Host "Extracting MPV update..."
        & $zipTool x (Join-Path $tempPath $mpvFilename) ("-o" + (Join-Path $tempPath "lib\")) -y
        if ($plexProcess) {
        Write-Host "Copying updated MPV files..."
        Copy-Item -Path (Join-Path $tempPath "lib\mpv-2.dll") -Destination $localInstallPath -Force -Confirm:$false
        if ($plexProcess) {
        Write-Host "MPV update completed successfully! New version: $Version"
        $updatedDate = Get-MPVDLLDate
        if ($updatedDate -eq $Version.Substring(0, 10)) {
            Write-Host "MPV update verified successfully."
        else {
            Write-Host "MPV update verification failed. Please check manually."
            Write-Host "Expected date: $($Version.Substring(0, 10))"
            Write-Host "Actual date: $updatedDate"
        Remove-Item -Path (Join-Path $tempPath $mpvFilename) -Force -ErrorAction SilentlyContinue
    catch {
        Write-Host "An error occurred during the MPV update process: $_"
    finally {
function Ensure-NanaZipInstalled {
    $nanaZipInstalled = Get-AppxPackage | Where-Object { $_.Name -like "*NanaZip*" }
    if ($nanaZipInstalled) {
        Write-Host "NanaZip is already installed."
        return $true
    $wingetPath = Get-Command winget -ErrorAction SilentlyContinue
    if (-not $wingetPath) {
        Write-Host "Winget is not installed. Please install the Windows Package Manager (winget) to proceed."
        return $false
    Write-Host "Attempting to install NanaZip..."
    try {
        winget install -e --force --id M2Team.NanaZip --accept-package-agreements --accept-source-agreements
            Write-Host "NanaZip has been successfully installed."
            return $true
        else {
            Write-Host "NanaZip installation seems to have failed. Please check for any error messages above."
            return $false
    catch {
        Write-Host "An error occurred while trying to install NanaZip: $_"
        return $false
# Main script
Write-Host "Starting update check for Plex HTPC and MPV..."
# Global variables
$localInstallPath = "C:\Program Files\Plex\Plex HTPC\"
$tempPath = "$env:TEMP\plexhtpc\"
$zipTool = "nanazipc"
#Start update check
if (!(Ensure-NanaZipInstalled)) {
    Write-Host "Failed to make sure nanazip is installed and usable. The script will not work without it."
    Exit 1
$plexUpdateInfo = Check-PlexHTPCUpdate
if ($plexUpdateInfo) {
    Write-Host "Updating Plex HTPC..."
    Update-PlexHTPC -Download $plexUpdateInfo.Download -Version $plexUpdateInfo.Version
else {
    Write-Host "No Plex HTPC update required."
$mpvUpdateInfo = Check-MPVUpdate
if ($mpvUpdateInfo) {
    Write-Host "Updating MPV..."
    Update-MPV -Download $mpvUpdateInfo.Download -Version $mpvUpdateInfo.Version
else {
    Write-Host "No MPV update required."
Write-Host "Update process completed."
This is fantastic! Thank you for this! It’s the solution for my issue Fix for Plex HTPC stuttering / laggy playback issue on certain 4K content, please upstream - #24
@Mitzsch could be a good idea to link to this from Dolby TrueHD passthrough - modified mpv build
I think it should also be easy to modify this script to keep a copy of both the latest stock and mitzsch build locally so they can be toggled to fix Some "Movies & Shows On Plex" streaming videos will not playback - #8
I believe that with this script running at boot and on resume, and also killing and restarting Plex HTPC app on resume (Plex HTPC should automatically reconnect after resume from sleep / internet availability - #2 by dancb2) I should also avoid Playback Error [existsOrThrow] Value is undefined or null! - #25 by dancb2 and have a fully functioning Plex HTPC app waiting for use on screen at all times.
I just need to spend a little time and investigate Plex HTPC for Windows should add "comfort sound" to prevent sound delay on pause - #9 by dancb2 now
Glad you liked it :slight_smile: I have refined the script today and added tons of extra error handling is something goes wrong. More helpful output of information during the script execute. Automatic backup of the current mpv-2.dll if a new version is found. Should be much more robust and will handle any errors that might occur gracefully and informative.
    [CmdletBinding()]
    param (
        try {
            else {
        catch {
            Write-Host "An error occurred while processing the file. Error:"`e[31m"$($_.Exception.Message)"`e[0m""
    else {
        Write-Host "Plex HTPC executable not found at the specified path." -ForegroundColor Red
        Write-Host "Plex HTPC not installed. Install manually." -ForegroundColor Yellow
        return $null
    try {
        Write-Host "Successfully got data from plex.tv." -ForegroundColor Green
    catch {
        Write-Host "Could not fetching data from plex.tv. Error:"`e[31m"$($_.Exception.Message)"`e[0m""
        return $null
        Write-Host "Plex HTPC is up-to-date." -ForegroundColor Green
        Write-Host "Current Plex HTPC version:"`e[32m"[$($localVersion.LocalVersion)]"`e[0m" same as latest online version:"`e[32m"[$downloadVersion]"`e[0m""
        return $null
    else {
        Write-Host "Plex HTPC is NOT up-to-date." -ForegroundColor Yellow
        Write-Host "Current Plex HTPC version:"`e[32m"[$($localVersion.LocalVersion)]"`e[0m" is NOT same as latest online version:"`e[32m"[$downloadVersion]"`e[0m". Will update!"
        return @{
function Compare-MPVVersion {
    [CmdletBinding()]
    param (
        [string]$Version
    $versionPattern = '(?<minor>\d+)\.(?<patch>\d+)[_-](?<build>\d+)[_-](?<revision>\d+)'
    if ($Version -match $versionPattern) {
        $minor = $matches['minor']
        $patch = $matches['patch']
        $build = $matches['build']
        $revision = $matches['revision']
        $patch = if ($patch) {
            $patch
        else {
            '0'
        $build = if ($build) {
            $build
        else {
            '0'
        $revision = if ($revision) {
            $revision
        else {
            '0'
        $customVersionString = "$minor.$patch.$build.$revision"
        return $customVersionString
    if ($Version -match '-UNKNOWN') {
        return ($version -split '-')[0]
    return $null
function Get-MPVVersion {
    [CmdletBinding()]
    param (
        [switch]$CompareVersion
    try {
        $mpvOnlineResponse = Invoke-RestMethod -Uri "https://api.github.com/repos/mitzsch/mpv-winbuild/releases/latest"
        $mpvDownloadUrl = ($mpvOnlineResponse.assets | Where-Object name -Like "mpv-dev-x86_64-v3-*").browser_download_url
    catch {
        Write-Host "Could not get MPV version info from github. Error:"`e[31m"$($_.Exception.Message)"`e[0m""
        return @{
            NeedUpdate        = $false
            Version           = $null
            VersionDownloaded = $false
            URL               = $null
    if ($CompareVersion.IsPresent) {
        New-Item -Path $tempPath -ItemType Directory -Force -ErrorAction SilentlyContinue | Out-Null
        try {
            Invoke-WebRequest -Uri $mpvDownloadUrl -OutFile (Join-Path $tempPath ([System.IO.Path]::GetFileName($mpvDownloadUrl)))
            Write-Host "Successfully downloaded the latest mpv client to compare against." -ForegroundColor Green
            & $zipTool x (Join-Path $tempPath ([System.IO.Path]::GetFileName($mpvDownloadUrl))) ("-o" + (Join-Path $tempPath "lib\")) -y | Out-Null
            Write-Host "Successfully extraced the mpv update..." -ForegroundColor Green
        catch {
            Write-Host "Something went wrong when downloading or extracting the latest mpv client. Error:"`e[31m"$($_.Exception.Message)"`e[0m""
            return @{
                NeedUpdate        = $false
                Version           = $null
                URL               = $null
        try {
            $online = (Get-Item -Path "$tempPath\lib\mpv-2.dll").VersionInfo.FileVersion
            $local = (Get-Item (Join-Path $localInstallPath "mpv-2.dll")).VersionInfo.FileVersion
            [version]$localVersion = Compare-MPVVersion -Version $local
            [version]$onlineVersion = Compare-MPVVersion -Version $online
            if ($onlineVersion -and $localVersion -and $onlineVersion -gt $localVersion) {
                return @{
                    NeedUpdate        = $true
                    Version           = $onlineVersion
                    VersionDownloaded = $true
                    URL               = $mpvDownloadUrl
            else {
                return @{
                    NeedUpdate        = $false
        catch {
            Write-Host "Could not compare versions mpv version. Error:"`e[31m"$($_.Exception.Message)"`e[0m""
            return @{
                NeedUpdate        = $false
                Version           = $null
                URL               = $null
    try {
        [datetime]$localVersionDate = (Get-Item (Join-Path $localInstallPath "mpv-2.dll")).LastWriteTime.ToString("yyyy-MM-dd")
        [datetime]$onlineVersionDate = ($mpvOnlineResponse.tag_name).Substring(0, 10)
        if ($onlineversiondate -and $localVersionDate -and $onlineVersionDate -gt $localVersionDate) {
            return @{
                NeedUpdate        = $true
                Version           = $onlineVersionDate
        else {
            return @{
                NeedUpdate        = $false
                Version           = $null
    catch {
        return @{
            NeedUpdate        = $false
            Version           = $null
            URL               = $null
    [CmdletBinding()]
    param(
        [switch]$CompareVersion,
        [switch]$KeepCurrentVersion
    if ($KeepCurrentVersion.IsPresent) {
        Write-Host "Keeping current MPV version."
        Write-Host "Current local mpv version is:"`e[32m"[$((Get-Item (Join-Path $localInstallPath "mpv-2.dll")).VersionInfo.FileVersion)]"`e[0m""
        return
    $needUpdate = if ($CompareVersion.IsPresent) {
        Get-MPVVersion -CompareVersion
    else {
        Get-MPVVersion
    if ($needUpdate.NeedUpdate -eq $true -and $needUpdate.URL ) {
        Write-Host "New MPV version available:"`e[32m"[$($needUpdate.Version)]"`e[0m""
        return @{
            Download          = $needUpdate.URL
            Version           = $needUpdate.Version
            VersionDownloaded = $needUpdate.VersionDownloaded
    else {
        Write-Host "Local mpv version"`e[32m"[$((Get-Item (Join-Path $localInstallPath "mpv-2.dll")).VersionInfo.FileVersion)]"`e[0m" is up to date."
    if ((Get-Item (Join-Path $localInstallPath "mpv-2.dll")).Length -lt 50000000) {
        Write-Host "You are using the original PlexHTPC mpv client."
    else {
        Write-Host "You are using a custom modified PlexHTPC mpv and not the standard PlexHTPC mpv client."
function Stop-RestartPlexHTPC {
    [CmdletBinding()]
    param(
        [switch]$Restart
    if ($Restart.IsPresent) {
        try {
            Start-Process -FilePath (Join-Path $localInstallPath "Plex HTPC.exe") -WindowStyle Hidden -ErrorAction Stop
            Write-Host "Plex HTPC successfully restarted!" -ForegroundColor Green
        catch {
            Write-Host "Something went wrong when restarting Plex HTPC. Error:"`e[31m"$($_.Exception.Message)"`e[0m""
        return
    if ($plexProcess) {
        try {
            $plexProcess | Stop-Process -Force -Confirm:$false -ErrorAction Stop
            Write-Host "Successfully stopped Plex HTPC before the update." -ForegroundColor Green
        catch {
            Write-Host "Something went wrong when stopping Plex HTPC. Error:"`e[31m"$($_.Exception.Message)"`e[0m""
    else {
        Write-Host "Plex HTPC is not running. Nothing to stop." -ForegroundColor Yellow
    [CmdletBinding()]
    param (
        [Parameter(Mandatory = $true)][string]$Download,
        [Parameter(Mandatory = $true)][string]$Version
    try {
        try {
            Write-Host "Successfully downloaded the new Plex HTPC client." -ForegroundColor Green
            & $zipTool x (Join-Path $tempPath $plexFilename) ("-o" + (Join-Path $tempPath "app\")) -y | Out-Null
            Write-Host "Successfully extraced the Plex HTPC update..." -ForegroundColor Green
        catch {
            Write-Host "Something went wrong when downloading or extracting the new Plex HTPC client. Will abort the update. Error:"`e[31m"$($_.Exception.Message)"`e[0m""
            return
        try {
            Copy-Item -Path (Join-Path $tempPath "app\*") -Destination $localInstallPath -Recurse -Exclude '$PLUGINSDIR', '$TEMP', "*.nsi", "*.nsis" -Force -ErrorAction Stop
            Write-Host "Plex HTPC update completed successfully! New version:"`e[32m"[$Version]"`e[0m""
        catch {
            Write-Host "Something went wrong during Plex HTPC update. Will abort the update. Error:"`e[31m"$($_.Exception.Message)"`e[0m""
            return
        Stop-RestartPlexHTPC -Restart
    catch {
        Write-Host "An error occurred during the Plex HTPC update process:"`e[31m"$($_.Exception.Message)"`e[0m""
    finally {
    [CmdletBinding()]
    param (
        [Parameter(Mandatory = $true)][string]$Version,
        [switch]$VersionDownloaded,
        [switch]$Force
    try {
        if ($VersionDownloaded.IsPresent) {
            try {
                Write-Host "Starting MPV update process... Latest version is already downloaded. Copying new mpv-2.dll to $localInstallPath..."
                Copy-Item -Path (Join-Path $tempPath "lib\mpv-2.dll") -Destination $localInstallPath -Force -Recurse -Confirm:$false -ErrorAction Stop | Out-Null
                Write-Host "MPV update completed successfully! New version:"`e[32m"[$Version]"`e[0m""
            catch {
                Write-Host "Something went wrong during MPV update. Error:"`e[31m"$($_.Exception.Message)"`e[0m""
            return
        try {
            Write-Host "Successfully downloaded the new mpv client." -ForegroundColor Green
            & $zipTool x (Join-Path $tempPath $mpvFilename) ("-o" + (Join-Path $tempPath "lib\")) -y | Out-Null
        catch {
            Write-Host "Something went wrong when downloading or extracting the new mpv client. Will abort the update. Error:"`e[31m"$($_.Exception.Message)"`e[0m""
            return
        New-Item -Path $backupDir -Force -Confirm:$false -ErrorAction SilentlyContinue | Out-Null
        try {
            Copy-Item -Path ("$localInstallPath" + "mpv-2.dll") -Destination $backupDir -Force -Confirm:$false -ErrorAction Stop | Out-Null
            Write-Host "Successfully backed up the current mpv client to"`e[32m"[$backupDir\mpv-2.dll]"`e[0m"."
        catch {
            if($Force.IsPresent) {
                Write-Host "Something went wrong when trying to backup the current mpv client. Will contune since -Force was specified. Error:"`e[31m"$($_.Exception.Message)"`e[0m""
            else {
                Write-Host "Something went wrong when trying to backup the current mpv client. Will abort since -Force was not specified. Error:"`e[31m"$($_.Exception.Message)"`e[0m""
                return
        try {
        catch {
            Write-Host "Something went wrong during MPV update. Will abort the update. Error:"`e[31m"$($_.Exception.Message)"`e[0m""
            return
    catch {
        Write-Host "An error occurred during the MPV update process. Will abort the update. Error:"`e[31m"$($_.Exception.Message)"`e[0m""
    finally {
        Write-Host "NanaZip version"`e[32m"[$($nanaZipInstalled.Version)]"`e[0m" is already installed."
        return $true
        Write-Host "Winget is not installed. Please install the Windows Package Manager (winget) to proceed." -ForegroundColor Red
        return $false
    try {
        Start-Process -FilePath $wingetPath.Source -ArgumentList "install -e --force --id M2Team.NanaZip --accept-package-agreements --accept-source-agreements --silent" -Wait -NoNewWindow
            Write-Host "NanaZip version"`e[32m"[$($nanaZipInstalled.Version)]"`e[0m" has been successfully installed."
            return $true
        else {
            Write-Host "NanaZip installation seems to have failed. Please check for any error messages above." -ForegroundColor Red
            return $false
    catch {
        Write-Host "An error occurred while trying to install NanaZip. Error:"`e[31m"$($_.Exception.Message)"`e[0m""
        return $false
# Main script
# Global variables
$backupDir = "$localInstallPath" + "Backup"
#Start update check
    Exit 1
else {
$mpvUpdateInfo = Check-MPVUpdate -CompareVersion #With -CompareVersion it will download the latest mpv client and check the dll version to compare with. Without -CompareVersion it will just compare the date of the local dll with latest on Github.
    Update-MPV -Download $mpvUpdateInfo.Download -Version $mpvUpdateInfo.Version -VersionDownloaded:$mpvUpdateInfo.VersionDownloaded -Force #-Force is used to ignore if the script is unabled to backup the current mvp client.
else {
I have tweaked it further so i feel its good enough to publish on Github :slight_smile:
-Added custom logging like this:
[2024-08-22 21:51:41.925][SUCCESS] NanaZip version [3.1.1080.0] is already installed. [Function: Ensure-NanaZipInstalled]
[2024-08-22 21:51:43.332][SUCCESS] Successfully downloaded the latest mpv client to compare against. [Function: Get-MPVVersion]
[2024-08-22 21:51:44.130][SUCCESS] Successfully extraced the mpv update... [Function: Get-MPVVersion]
[2024-08-22 21:51:44.163][SUCCESS] Local mpv version: [v0.38.0_4-243-g718fd0d8] is up to date. [Function: Check-MPVUpdate]
[2024-08-22 21:51:44.164][INFO] You are using a custom modified PlexHTPC mpv and not the standard PlexHTPC mpv client. [Function: Check-MPVUpdate]
[2024-08-22 21:51:44.193][INFO] No MPV update required.
[2024-08-22 21:51:44.347][SUCCESS] Successfully got data from plex.tv. [Function: Check-PlexHTPCUpdate]
[2024-08-22 21:51:44.394][SUCCESS] Plex HTPC is up-to-date. [Function: Check-PlexHTPCUpdate]
[2024-08-22 21:51:44.395][SUCCESS] Current Plex HTPC version: [1.66.1.215] same as latest online version: [1.66.1.215] [Function: Check-PlexHTPCUpdate]
[2024-08-22 21:51:44.407][INFO] No Plex HTPC update required.
[2024-08-22 21:51:44.411][SUCCESS] Update process completed.
  • Fixed slow download speed on PS 5.1, its about 10 times faster.
Link:
I wonder if anyone knows of any simple tools to create a GUI executable to run powershell scripts? It would be super cool to have a light utility to call functions of this script and maybe even extended features like toggling between stock and mitzsch dll, toggling mpv.conf flags like RTX super resolution etc.
I will rephrase the first post in the truehd thread in a few days and will link this one here. :wink:
