I really could do with some help. I had to restore my Seagate Personal Cloud 5TB and plex stopped working.
I then realised music had moved to another folder under a Recovery directory.
I then moved all the music back under Public\Music and reinstalled the Plex Media Server App nto the NAS device.
I now am trying to add the music library back but it keeps telling me “Your Changes Could Not be Saved.”
I am attaching a screenshot and the logs. Need help please as I am really not technical at all
same here. i just got a seagate personal cloud this weekend and i keep getting this same error message when i try to configure plex. i’ve looked at other threads that seem to be discussing this issue (or something like it) but i’m not techno-savvy enough to quite understand how to fix this based on those other replies.
I am having the same issue. Just received a Seagate Personal Cloud that I purchased because it runs Plex and cannot save a library, screen looks like the post above. I have tried this in both the Plex Media Player app (Win 10) and Chrome. I have another Plex server on the network running on Win 10 and can connect, create directories, and play from that without any problems on Chrome, Plex Media Player (Win 10 and FTV).
Definitely interested in signing up for a Plex Pass but won’t do it unless it works for me.
I’ve been having this issue myself as well and I think I figured it out…
When naming the library you’re trying to add, make sure you give it the exact same name as the name of the directory (folder). So, for example, if you have a folder named “superhero movies” that you want to add, make sure you name it “superhero movies” when adding it to your Plex library.
@jefflaing said:
I’ve been having this as well, though I may be different because I have another Plex Server (that this one is replacing) on the same network.
Just this minute (literally) I found that changing the Settings>Server>Network>Enable Discovery (GDM) to off appears to have fixed the problem.
I have another server on the network as well. So I tried to try your fix, but when I try to open Settings>Server I get a message saying “Server settings are unavailable.” AARGH!
Im having the same issue, installed new from the Seagate dash and now it wont let me save the location of the files… i tried to reinstall 3 times rebooted the drive and same thing.
Does anyone have a solution for this that works im using a Seagate 4bay NAS and am having the same issue i have tried reinstalling plex. .making the shared folder public… rebooting but no matter what i do i keep getting the same message and can not add librarys
