If you use Settings - Server - Help - Download Logs , it will contain what I need.
FYI. Docker is a P.I.T.A
OK, let’s try this ones. BTW, have no problems with the docker whatsoever. Well, except search is case sensitive
@ChuckPA, any updates?
I did submit it to engineering with your screen shots. Thank you!
Due to the holiday in the US (Thursday) there has not been much activity Wed-Thurs-Fri.
Cool! I just didn’t know if the last set of logs I uploaded had everything you need. Happy Thanksgiving!
version 1.10.1.4602 and bug still here
Hi guys!
Are you going to fix this annoying bug?
I’ve been using Plex since 2015 and the bug is still here with the latest version i’ve just downloaded!
I have also found a topic with the same issue described a long time ago
Same problem.
Search is case sensitive (for cyrillic characters)
Server version 1.13.8.5395 - same problem!
2 years have passed, 2 lines of code have not yet been added.
3 years, nothing changed.
Im here to say that a bug is still there and it is really annoying)
server: 1.14.1.5488
version 1.15.4.919 - nothing changed
Three years passed, but the developers have not corrected the search in languages other than Cyrillic!
Bug with the search is still present.
But the music was also added to the photo upload.
v 1.15.3.876 on debian
Why is it so difficult? Just please be sure that part of Plex users are not english-speakers, and have troubles with this issue.
Please increase it’s priority. It’s definitely 2lines fix
plexmediaserver:
Installed: 1.16.3.1402-22929c8a2
ChuckPA Were you able to reproduce issue on your side?
plexmediaserver version: 1.18.1.2019
issue still here
Time flies, but obviously easy-to-fix problem stays forever. Priorities!
